[Bitrix\Main\DB\ConnectionException]
Mysql connect error [mariadb-prod]: (1040) Too many connections (400)
/var/www/html/bitrix/modules/main/lib/db/mysqliconnection.php:88
#0: Bitrix\Main\DB\MysqliConnection->connectInternal()
	/var/www/html/bitrix/modules/main/lib/data/connection.php:53
#1: Bitrix\Main\Data\Connection->getResource()
	/var/www/html/bitrix/modules/main/lib/db/mysqlisqlhelper.php:21
#2: Bitrix\Main\DB\MysqliSqlHelper->forSql(string)
	/var/www/html/bitrix/modules/main/lib/config/option.php:206
#3: Bitrix\Main\Config\Option::load(string)
	/var/www/html/bitrix/modules/main/lib/config/option.php:83
#4: Bitrix\Main\Config\Option::getRealValue(string, string, boolean)
	/var/www/html/bitrix/modules/main/lib/config/option.php:32
#5: Bitrix\Main\Config\Option::get(string, string, string)
	/var/www/html/bitrix/modules/main/lib/httprequest.php:420
#6: Bitrix\Main\HttpRequest->prepareCookie(array)
	/var/www/html/bitrix/modules/main/lib/httprequest.php:77
#7: Bitrix\Main\HttpRequest->__construct(object, array, array, array, array)
	/var/www/html/bitrix/modules/main/lib/httpapplication.php:44
#8: Bitrix\Main\HttpApplication->initializeContext(array)
	/var/www/html/bitrix/modules/main/lib/application.php:133
#9: Bitrix\Main\Application->initializeExtendedKernel(array)
	/var/www/html/bitrix/modules/main/include.php:23
#10: require_once(string)
	/var/www/html/bitrix/modules/main/include/prolog_before.php:14
#11: require_once(string)
	/var/www/html/bitrix/modules/main/include/prolog.php:10
#12: require_once(string)
	/var/www/html/bitrix/header.php:1
#13: require(string)
	/var/www/html/firewall-FSTEC/index.php:2
